Array Profile Plotting
In the database window, use the right-click menu option Array Profile Plotting (VAPLOT GX) to generate a plot of an individual array profile from an array channel in the current database.
This GX must be run interactively.
Plot Individual Array Profile dialog options
Title |
Enter the title to be displayed at the top of the figure. |
X Axis Annotation |
Provide the annotation for the X-axis, shown at the bottom of the figure. |
Y Axis Annotation |
Provide the annotation for the Y-axis, shown on the right of the figure. |
Profile width (mm) |
Specify the width of the figure in millimetres. |
Profile height (mm) |
Specify the height of the figure in millimetres. |
Profile colour |
Select the colour to be used for the figure. |
To adjust the number of decimals shown, modify the decimal precision in the channel definition.
database_line_fidnum.map".To avoid overwriting:
Enter a different map name in the dialog, or
Rename the existing map using Map > Save As… from the map window.
