Array Section Colours
In the database window, use the right-click menu option Array Section Colours (VASCTCOL GX) to specify a colour zone file for rendering an Array channel within each database cell.
Set Section Colours for an Array Channel dialog options
Array channel |
Select the array channel to be displayed. Script Parameter: VASCTCOL.CHAN |
Colour table |
Select the colour scheme used to render the colour zone file:
Script Parameter: VASCTCOL.FILE |
The selected colour scheme file will be applied to display the array channel in each database cell when the section display option is enabled (see Array Profile/Section Options).
If the selected file is not a colour zone file, colours will be assigned using a Linear distribution.
