Extract View Mask to PLY File
Use the Map Tools > Masking > Extract Current View Mask to PLY File option (VIEWGETCLIP GX) to export the mask polygon associated with a selected view to a PLY file (*.ply).
Extract Current View Mask to PLY File dialog options
Clip polygon file (.ply)
Specify the output PLY file that will store the extracted mask polygon. Enter a file name or browse to select a location.
Script Parameter: VIEWGETCLIP.FILE
Map view
Select the view whose mask polygon will be exported.
Options may include Data, Base, or other available views (for example, Section).
Script Parameter: VIEWGETCLIP.VIEW
  • This tool operates on the mask associated with the selected view, not the currently displayed map area.
  • The exported polygon corresponds to the view mask, not the current zoom level or the visible area of the map window (viewport).
  • The exported polygon may appear as a rectangular boundary covering the selected view, depending on the mask associated with that view.
  • To better understand how masks are defined and applied, see Apply View Mask (VIEWCLIP GX).
  • Exporting the current viewport extents (the visible map area) as a polygon is not supported by this tool.
