Window X,Y to Zmin/Zmax Mask
Use the Database Tools > Window Data > Window X,Y to Zmin/Zmax Mask menu option (WINZ GX) to window the X and Y channels to the area defined by a given range Zmin/Zmax of a mask channel (Z). This restricts all subsequent map-based processing to data within the defined region.
Window X,Y to Zmin/Zmax Mask dialog options
Mask channel (Z) name |
Mask channel name. Script Parameter: WINZ.ZCH |
Z min |
Min value of mask range. Script Parameter: WINZ.ZMIN |
Z max |
Max value of mask range. Script Parameter: WINZ.ZMAX |
This GX is used to limit the X and Y coordinates to the part of the area to be plotted. All MAP based processes will use the X and Y channels as the plotting coordinates. By dummying those parts of the area outside the area of interest, all plotting will be restricted to the defined area. Subsequent windowing operations with WINZ will apply to the current windowed coordinates.
A copy of the original X and Y channels is saved to __X and __Y (if these channels do not already exist). Future windowing operations will use these channels as the source channels.
