The Drillhole Dataset selector is found on the Target ribbon, within the Current Dataset group.
When working in a project with more than one drillhole dataset imported, use the Current Drillhole Dataset selector to choose which of the open drillhole datasets is the currently active dataset.
Multiple drillhole datasets can occur if you have:
More than one dataset imported via the Drillhole Data import tools
Another geodatabase opened, and which contains a drillhole dataset
If there is only one drillhole dataset present, the Current Drillhole Dataset selector will appear disabled (grayed out):
If there are multiple drillhole datasets, expand the dropdown list to select one of the drillhole datasets available in the project. The Current Drillhole Dataset will load under:
