Create Sections
Summary
The Create tab of the Section Tool can be used to create cross sections, by drawing the desired section location on the active scene or map.
Usage
At the top of the Create tab there is a tool strip with 5 buttons:
Defining a Section
Once you have clicked Create new section... (), the scene will rotate to a top-down (bird's eye) view, so that you can draw the sections extents by following these steps:
  1. Click once anywhere on the scene to start the section line. Drag the mouse cursor to create a line in any direction.
  2. Click a second time to end the line. Drag the mouse cursor to set the section thickness.
  3. Click a third time to finish the section. The section location parameters will appear with all the location values captured or calculated from the input drawing.
  4. The section location parameters appear in the tool and a red outline box appears in the scene to show the section location. You can click in any of the enabled fields to adjust the location, angles, or extents values to fine-tune the section as needed.
  5. If you wish to re-define the section, simply click the Create new section... button again, and re-define the section location.
Saving a Section
Pressing the Save button after the section location parameters are correctly set, will commit the current section location to the drillhole dataset. Once saved, the Section Tool will switch to the Manage Sections tab, which will result in the latest section, and any other sections in the dataset, appearing as outlines on the current scene or map.
Parameters
Parameter Explanation
New Section
Name
The name of the section. This will be automatically filled in based on the location.
Create Offset Sections
Slide the toggle on to create multiple, offset parallel sections. This can be used to create multiple sections that are parallel to the currently defined section.
Count
The number of offset sections to create, in addition to the original base section.
Separation
The separation spacing between offset sections. Enter a negative value to force the sections to be created in the opposite direction.
Reference Point: the reference point is located at the top-center of the section
Easting (X)
The X or easting location of the section reference point.
Northing (Y)
The Y or northing location of the section reference point.
Elevation (Z)
The Z or elevation location of the section reference point.
Offset
Offset toggle
Move section perpendicular to Azimuth. When working with angled sections, adjusting the easting or northing location of the reference point can lead to accidentally moving the section away from the desired location. This option allows you to hold the reference point and azimuth constant, while moving the section in a direction perpendicular to the azimuth.
Enabled by default, slide toggle to off position in order to adjust Easting or Northing locations independently.
Distance
Moves the section location by this distance, perpendicularly, from the original section location.
Angles
Azimuth
The angle of the section plane, measured clockwise from North (0°) degrees.
Inclination
The angle of the section plane, measured from horizontal (0°) degrees.
Extents
Length
The length of the section; changes to the length will expand the section outward in both directions from the center reference point.
Height
The height of the section; changes to the height will move the bottom of the section only. The top location is fixed by the reference point Z value.
Thickness
The thickness of the section; in the direction perpendicular to the length. Changes to the thickness will expand the section outward in both directions from the center reference point.
Scenes
Show extents as box
Slide on or off to view the sections extents in the current scene. Section extents appear as a red outline box.
Clip to extents
Slide on or off to temporarily clip the extents of the current scene to the extents of the section.
Clip to center plane
Slide on or off to temporarily clip the extents of the current scene to the center plane of the section.
Technical Notes
Parallel vs. Perspective Drawing Mode
When drawing section locations, it is much easier to achieve a precise location when in Parallel Drawing mode. If the scene is using Perspective Drawing mode, a warning will appear in a yellow text beneath the toolbar advising the user that sections might not be located as expected when using Perspective mode. Switching to Parallel mode will remove this warning, and provide a better experience when defining sections. The Drawing Mode selector is available on the View ribbon, in the Scene group. There is also a shortcut to this same control on the Create and Modify Section tabs.
Related Topics
