Use this tab to specify the import parameters for the Point (depth) data to be imported into the current geodatabase feature dataset. Once all the required fields are specified and mapped, the message “Ready to import <Point View> data” will display at the bottom of the tab and the OK button will be enabled.
| Parameter | Explanation | Data Type |
Point View |
The name of the selected Point (depth) data. This field is read-only.
Database Fields |
The database fields that are available for import. Select (highlight) a field to specify the Channel Type and parameters. |
Filter Conditions |
Click this button to open the Filter Conditions dialog. |
| Channel Type | ||
Not imported |
Select the Not imported option if you do not want the selected (highlighted) database field to be imported. |
Data |
Select the Data option if you want the selected (highlighted) database field to be imported as data. |
Hole ID |
Select the Hole ID option if you want the selected (highlighted) database field to be imported as Hole IDs. This is a required field. |
Depth |
Select the Depth option if you want the selected (highlighted) database field to be imported as "depth" data. This is a required field. |
Assay |
Select the Assay option if you want the selected (highlighted) database field to be imported as assay data. |
Sample |
Select the Sample option if you want the selected (highlighted) database field to be imported as sample data. |
Standard |
Select the Standard option if you want the selected (highlighted) database field to be imported as standard data. |
Duplicate |
Select the Duplicate option if you want the selected (highlighted) database field to be imported as duplicate data. |
| Parameters | ||
Field name |
Specify the field name. This field is read-only for required field types. |
Data type |
Specify the data type. This field is read-only for required field types. |
Data format |
Specify the data format. This field is read-only for required field types. |
Dummy |
Specify the alpha and /or numeric characters to be used as the dummy. The default is (*). |
Drillhole Import Wizard:
