Use this tab to specify the import parameters for the survey data to be imported into the current geodatabase feature dataset. Once all the required fields are specified and mapped, the message “Ready to import Dip-Azimuth Survey data” or “Ready to import East-North Survey data” will display at the bottom of the tab and the OK button will be enabled.
| Parameter | Explanation | Data Type |
Survey View |
The name of selected Survey data. This field is read-only. |
Survey type |
The survey type of the Survey data to be imported. This field is read-only.
Database Fields |
The database fields that are available for import. Select (highlight) a field to specify the Channel Type and parameters. |
Filter Conditions |
Click this button to open the Filter Conditions dialog. |
| Channel Type | ||
Not imported |
Select the Not imported option if you do not want the selected (highlighted) database field to be imported. |
Data |
Select the Data option if you want the selected (highlighted) database field to be imported as data. |
Hole ID |
Select the Hole ID option if you want the selected (highlighted) database field to be imported as Hole IDs. This is a required field. |
Depth |
Select the Depth option if you want the selected (highlighted) database field to be imported as depth data. This is a required field for the survey type dip-azimuth. |
Dip |
Select the Dip option if you want the selected (highlighted) database field to be imported as collar dip data. This is a required field for the survey type dip-azimuth. |
Azimuth |
Select the Azimuth option if you want the selected (highlighted) database field to be imported as azimuth. This is a required field for the survey type dip-azimuth. |
Easting |
Select the Easting option if you want the selected (highlighted) database field to be imported as easting survey data. This is a required field for the survey type easting-northing. |
Northing |
Select the Northing option if you want the selected (highlighted) database field to be imported as northing survey data. This is a required field for the survey type easting-northing. |
RL |
Select the RL option if you want the selected (highlighted) database field to be imported as RL (Elevation) data. This is a required field for the survey type easting-northing. |
| Parameters | ||
Field name |
Specify the field name. This field is read-only for required field types. |
Data type |
Specify the data type. This field is read-only for required field types. |
Data format |
Specify the data format. This field is read-only for required field types. |
Dummy |
Specify the alpha and /or numeric characters to be used as the dummy. The default is (*). |
Drillhole Import Wizard:
