Imports subsurface drillhole or borehole data from MX Deposit into a feature dataset in a geodatabase.
The imported drillhole data will be stored in a feature dataset (called "Drillholes"), with feature classes created for each data type that is associated with the imported drillholes:
When importing data from MX Deposit, the imported symbology can be applied to any drillhole attribute or feature layer.
A Refresh option can be used to quickly update the imported drillholes with the latest up-to-date data from the MX Deposit database.
| Parameter | Explanation | Data Type |
Output Drillhole Dataset |
The name of the geodatabase feature dataset in which to store the imported drillhole data. |
MX Deposit Project |
The list of projects currently available in the MX Deposit database.
Activity |
The list of activities associated with the selected MX Deposit project.
Coordinate system |
The coordinate system to be used to spatially reference the imported drillhole data. Defaults to the top ranked coordinate system in the MX Deposit project tables.
MX Deposit is a cloud-based logging application designed to help mining and exploration companies simplify and modernize how drilling and geological sample data is collected, managed, and shared. MX Deposit drillhole data can be logged and accessed from anywhere in the world. The MX Deposit application has been initially integrated with the Geosoft applications, Target and Target for ArcGIS and enabled explorers to easily import drillhole projects from MX Deposit directly into the Geosoft environment and to provide easy interaction between the MX Deposit source database and the imported drillholes. The integration with Target Pro enables the import of drillhole projects from MX Deposit directly into the ArcGIS Pro environment.
The drillholes are always "desurveyed" on import, which means a 3D spatial object (a drillhole "trace") is calculated for each drillhole. The output trace for any given hole can vary depending on what type of data is available during import (collars only, vs. collar and survey data) and which method is selected to do the desurvey calculations, as well as the resolution value selected. The various ways to calculate the traces, depending on which types of data are available, are described below:
With collar locations only, no survey data present:
With collar locations and dip-azimuth survey data:
Learn more about Resurvey Holes.
