Check for Updates
New capabilities and features are added to Target for ArcGIS Pro regularly to improve the existing functionality of the system and simplify the user experience.
You can check for software updates at your own convenience and set your update options using the Seequent Connector. By default, Target for ArcGIS Pro automatically checks for updates when it is opened.
Seequent Connector checks for updates to releases as they become available. The system also checks for updates to Seequent Connector.
To Check for and Install an Update:
From the Target tab, select the Help menu, then select Software Updates. The system will check for any available software updates.
You can also check for software updates by right-clicking the Seequent Connector icon
on your system tray and selecting Check for Updates.If there are no updates available, the Seequent Connector notification in your system tray informs you that the application(s) are up to date. The version number is displayed beside each of the installed applications.
If there is an update available, the option to update will be enabled in the Seequent Connector notification.
If applicable, a link to the Release Notes page will be available. Click on the link to learn what is new in the available software update and access the full release notes.
To update, click Install Update. The system will begin to download and initiate the update process.
To Schedule Check for Updates:
Right-click the Seequent Connector icon
in your system tray and expand the Check for Update Options menu.
Select the frequency at which you want the system to check for updates. Your selection will have a check mark next to it. The default is "At Application Startup".
Related Topics:
