Text Data - Drillhole Import Wizard - Step 2 of 3 (Delimited)
Summary
Use this wizard dialog to specify how the delimited data is formatted in the import data file.
| Parameter | Explanation | ||
| Column Delimiters | |||
Microsoft Excel CSV |
Select the Microsoft Excel CSV option if the import data is in CSV format. | ||
Comma Delimited |
Select the Comma Delimited option if the import data columns are separated by a comma. |
White Space Delimited |
Select the White Space Delimited option if the import data columns are separated by white space. |
Tab Delimited |
Select the Tab Delimited option if the import data columns are separated by a tab. |
Other |
Select the Other option if the import data columns are separated by another method. |
Select Soft if you want the delimiter to be flexible on recognizing spaces, commas, tabs, etc. For example, if you select Soft and a space is encountered in the column it will be ignored. If however, you select Hard and the same space was encountered, the column will be split into two. |
String Handling |
Quote character |
Specify the "character" to be used for quotes. The default is ' " '. |
Escapes? |
Select Escapes? if there are escape sequences in your data. Special characters in a string can be defined using escape sequences. An escape sequence consists of a backslash character (\) followed by one or more characters. |
Preview window |
Column Locations |
The column locations, as have been determined by the parameters above, will be displayed in this window. | ||
Next> |
Click the Next> button to continue the import process. |
Related Topics
Text Data - Drillhole Import Wizard:
Import Drillholes from Text Files
