Text Data - Drillhole Import Wizard - Step 1 of 3
Summary
Use this wizard dialog to specify how the data in the import text file is formatted.
| Parameter | Explanation |
| File Type | |
Delimited |
Select the Delimited option if the import data is in a delimited format (spaces or commas separate each data field). |
Fixed Field |
Select the Fixed Field option if the import data is in a fixed field format (data is aligned in fixed width within columns). |
| Row details | |
Number of rows |
Number of rows of data in the file. Note that, this value is determined from the import file and cannot be modified. |
Data headings on row |
Specify which row in the import file contains the headings. |
Data units on row |
Specify which row in the import file contains the data units. |
Start import on row |
Specify the first row in the import file that contains the data to import. |
Preview rows |
Specify how many rows to preview in the preview window below. |
Preview window |
File name |
The line directly above the preview window displays the name of the file that is being imported. |
Display window |
The window at the bottom of the dialog box displays the ASCII data file to be imported. |
Next> |
Click the Next> button to continue the import process. |
Related Topics
Text Data - Drillhole Import Wizard:
Import Drillholes from Text Files
