Text Data - Drillhole Import Wizard - Step 2 of 3 (Delimited)
Summary
Use this wizard dialog to specify how the delimited data is formatted in the import data file.
Parameter Explanation
Column Delimiters
Microsoft Excel CSV
Select the Microsoft Excel CSV option if the import data is in CSV format.
Comma Delimited
Select the Comma Delimited option if the import data columns are separated by a comma.
White Space Delimited
Select the White Space Delimited option if the import data columns are separated by white space.
Tab Delimited
Select the Tab Delimited option if the import data columns are separated by a tab.
Other
Select the Other option if the import data columns are separated by another method.
Soft Hard
Select Soft if you want the delimiter to be flexible on recognizing spaces, commas, tabs, etc. For example, if you select Soft and a space is encountered in the column it will be ignored. If however, you select Hard and the same space was encountered, the column will be split into two.
String Handling
Quote character
Specify the "character" to be used for quotes. The default is ' " '.
Escapes?
Select Escapes? if there are escape sequences in your data.
Special characters in a string can be defined using escape sequences. An escape sequence consists of a backslash character (\) followed by one or more characters.
Preview window
Column Locations
The column locations, as have been determined by the parameters above, will be displayed in this window.
Next>
Click the Next> button to continue the import process.
Related Topics
Text Data - Drillhole Import Wizard:
Import Drillholes from Text Files
