Text Data - Drillhole Import Wizard - Step 1 of 3
Summary
Use this wizard dialog to specify how the data in the import text file is formatted.
Parameter Explanation
File Type
Delimited
Select the Delimited option if the import data is in a delimited format (spaces or commas separate each data field).
Fixed Field
Select the Fixed Field option if the import data is in a fixed field format (data is aligned in fixed width within columns).
Row details
Number of rows
Number of rows of data in the file. Note that, this value is determined from the import file and cannot be modified.
Data headings on row
Specify which row in the import file contains the headings.
Data units on row
Specify which row in the import file contains the data units.
Start import on row
Specify the first row in the import file that contains the data to import.
Preview rows
Specify how many rows to preview in the preview window below.
Preview window
File name
The line directly above the preview window displays the name of the file that is being imported.
Display window
The window at the bottom of the dialog box displays the ASCII data file to be imported.
Next>
Click the Next> button to continue the import process.
Related Topics
Text Data - Drillhole Import Wizard:
Import Drillholes from Text Files
