Identify Used Library Items
Use the Identify Used Library Items option (Geosoft.uxo.gxnet.dll(Geosoft.GX.UXO.UxaIdentifyUsedItems;Run)*) from the menu AGC Expert User > Source and Library Management to flag library signatures that are matched against the Perform Library Match process.
Identify Used Library Items dialog options
Source Database | |
Name | Specify the source database name. Script Parameter:UXANALYZE.SOURCEGDB |
Group | Select the source group name. Script Parameter:UXANALYZE.SOURCEGROUP |
ID channel | Select the source ID channel name. Script Parameter:UXANALYZE.TARGETID |
Mask channel | Select the source mask channel name. Script Parameter:UXANALYZE.TARGETMASK |
Size channel | Select the source size channel name. Default value is UXA_SIZE. Script Parameter:UXANALYZE.TARGETSIZE |
Gates | Select the low and high gates, which will be passed to Perform Library Match that is executed in the background. Default value for low gate is 14 in case of TEM2x2x3 and 8 for other sensors. Default value for high gate is the maximum number of gates minus one. Script Parameter:
Library Database | |
Name | Specify the signature library database name. Script Parameter:UXANALYZE.LIBRARYGDB |
Group | Select the signature library group name. Script Parameter:UXANALYZE.LIBRARYGROUP |
Item description channel | Select the item description channel name. Script Parameter:UXANALYZE.LIBRARYID |
Output mask channel | Specify the mask channel name, which reflects the flagged library signatures. If the mask channel doesn't exist, it will be created. Script Parameter:UXANALYZE.LIBRARYMASK |
Output group | Specify the group name, in which the flagged library signatures will be saved. Script Parameter:UXANALYZE.LIBRARYGROUP2 |
Library match metric | Specify the library match metric, which is used to find the library items matching the source. Default value is 0.95. Script Parameter:UXANALYZE.LIBRARY_THRESHOLD |
Source Cluster Output | |
Minimum polarization amplitude | Specify the minimum polarization amplitude, which will be passed to Perform Library Match that is executed in the background. Default value is 0.001. Script Parameter:UXANALYZE.MIN_BETA_AMP |
Below are the processing steps used to flag library signatures that are matched against the Perform Library Match process.
Processing Steps
- Sort the sources based on low gate of size channel.
- Mask out the sources smaller than a minimum size, read from "uxa.config", for more information refer to uxa.config section below.
- Run library match with 111 weights, and mask out items with a metric exceeding the Library threshold.
- Mask out any sources without a valid library match, which is specified by -9999.
- Create and populate the output group and the optional mask channel in the library database.
Output Files
At the end of the process a new output Group and Mask channel is created in the Library database.
