Interactive Classification
Use the Interactive Classification modeless dialog to review the targets, fitting, and matching results and to repeat the ranking process. The tool is launched from the main Interactive Classification dialog.
Interactive Classification dialog options
General Information
Sensor name
Selected sensor type (read only).
Source database
Selected source database (read only).
Source group
Selected source group (read only).
Selected Point Information
Target ID
Shows the target ID of the selected point on the map if it exists in the target database.
Also, you are able to pick the target from the list of available IDs.
[Get Order from Database]
When selected, the target ID list is re-ordered to match the order in the target database.
Channel list
In this section various channel values will be shown. The following channels are shown by default:
  • Dig: Yes/No with a Red/Green background respectively - from UXA_Category, if 2 or less is Dig
  • Predicted Type: UXA_UXOTYPE (new channel)
  • Predicted Size: Small, Medium or Large - from UXA_SIZE
  • Predicted Depth: UXA_FIT_BGS - less than 30cm: 30cm and 60cm and greater than or equal 60cm
  • Comments: UXA_COMMENTS
[Add/Remove Channels]
When selected, the Selection Tool dialog is displayed, and you can add/remove channels to/from the channel list.
Show channels
When selected, all the channels, the default ones and the ones added by Selection Tool, will be displayed. Otherwise, just the default channel list is shown.
Default status is checked.
Script Parameter:UXANALYZE.SHOW_ADDED_CHANNELS
[Remove Measurement]
When selected, the tool will turn off the mask for all the instances of the flag ID and measurement ID, shown in the target ID field.
This will be done in the database groups associated with single, multiple, and multiple 2 criteria object solvers.
[Restore Measurement]
When selected, the Restore Measurements tool will turn on the mask for all the instances of the flag ID and measurement ID shown in the target ID field.
The tool will look through the target database for all flag IDs and measurements IDs that are masked and create a list for you to select from.
[Remove Source]
When selected, the tool will turn off the mask for the current target, shown in target ID field, in the original group.
This will be done in the database groups associated with single or multiple or multiple 2 criteria object solvers.
Actions
[Interactive Size Decay Plot]
When selected, the Scatter Analysis tool is launched.
[Pending Action; Rerank]
When selected, the tool will run Classify and Rank with the following individual options:
  • Set thresholds and prioritize
  • Create polarization plot with library (single source)
  • Create polarization plot with library (multiple sources)
  • Create decision map (classify)
[Pending Action; Remake Final Maps]
  • Create data map
  • Create polarization plot with library (cluster)
  • Create size and decay map (cluster)
  • Create size and decay map (classify)
Interactive Classification is a modeless tool, similar to the Project Explorer and can be docked within the Oasis montaj project window.
  • When moving around the Interactive Classification tool, if you hold down the <Ctrl> key while you are moving the tool, it will not dock on the sides, top or bottom of the Geosoft project window. Let go of the <Ctrl> key and move again to dock.
