Interactive Classification Settings
Use the Interactive Classification option (Geosoft.uxo.gxnet.dll(Geosoft.GX.UXO.UxaLaunchInteractiveClassification;Run)*) to set some parameters and run the modeless Interactive Classification tool.
UX-Analyze extension:
- AGC Static Data > Review Classification
- AGC Expert User > Source Classification and Review
Interactive Classification dialog options
Prefix | Specify the databases prefix (e.g., SAM, SFR). Script Parameter:UXANALYZE.INTERACTIVE_CLASS_PREFIX |
Source group | Select the source group name. Script Parameter:UXANALYZE.SOURCEGROUP |
ID channel | Select the target ID channel. Script Parameter:UXANALYZE.TARGETID |
Mask channel | Select the target mask channel. Script Parameter:UXANALYZE.TARGETMASK |
Data channel | Select the data channel. Script Parameter:UXANALYZE._SENCHAN |
Gates | Select the low, high, and decay gates. Default values:
Script Parameter:
Lookup Tables
