Calculate Sample Separation
Use the Calculate Sample Separation option (UCEDATASEP GX) to flag data points that exceed the maximum data separation specification.
Sample Separation dialog options
Database name
Select the database to process.
Line selection
Select all or selected lines for processing
Script Parameter: UCEDATASEP.LINESEL
Maximum sample separation
Specify the nominal data separation
Script Parameter: UCEDATASEP.DATASEP
Cultural Mask File
Specify a polygon file (cultural mask ply file) to exclude masked areas.
Script Parameter: UCEDATASEP.CULTMASKFILE
New map?
You can display the results of UCEDATASEP either on the current map, or open a new map.
Script Parameter: UCEDATASEP.MAP
This quality control tool enables the user to flag in green lines with points that exceed a set maximum data separation.
Since the ordnance are typically of a smaller scale, it’s important to have a good number of points in a short range to be certain to increase detection.
  • To properly display the sample separation on the map, hide the groups previously displayed in the area of interest of the Index map.
  • Access Database
    When OK is clicked, the following information will be exported to the Along_Line_Spacing_Table table in the DID Access database if the database has been defined in the Setup Parameters dialog:
    GX Parameter
    Table Column
    Comment
    Database name
    Dataset_ID
    Name of the Geosoft database
    Min_Separation
    Minimum distance between data points, extracted from the statistics performed on the data
    Max_Separation
    Maximum distance between data points, extracted from the statistics performed on the data
    Mean_Separation
    Mean distance between data points
    StdDev_Separation
    Standard deviation of the distances between adjacent points
    Percent_Pass
    Percentage of points within data separation tolerance
    New map ?
    Separation_MapID
    Name of Geosoft UX-Process map generated this tool, if specified
