Data Types
The following data types are available for use. The data type codes are included in your database names.
Static Data Types
Data Type | Code | Description |
| Master Flag | SMASTER | The master data of the flag locations and survey metrics. |
| Modelled Data | SMD | Modelled or calculated target of interest (TOI) response data TOI (typically forward modelled). |
| Background Validation - Raw | SBR | Measurements used to determine whether a location is a potential background measurement location. |
| Background Validation - Validated | SBV | Data of validated background locations. Output of background validation test. |
| Function Test | SFT | Data from the sensor function test with the standard test item in the cradle. |
| Background Measurement | SBG | Background measurement at a non-anomalous location. |
| Quality Control (IVS) | SQC | Data collected over emplaced instrument verification strip (IVS) targets for quality control purposes. |
| Static Anomaly Measurement | SAM | Static survey measurements at locations with an unknown anomaly source for classification of potential targets of interest. |
| Seeded | SSD | Data that has been (synthetically) seeded. A calculated (forward modelled) target of interest (TOI) response has been added to the original dataset. |
| Reference Background | SRB | A background measurement associated with a specific SFR measurement. The database structure is an identical structure to SBG. |
| Function Reference | SFR | The 'Gold-Standard' of the response data of the reference item for the SFT comparison. The database structure is an identical structure to SAM. |
| Test Pit / Stand Measurement | STP | Test pit or test stand data. |
| Miscellaneous | SXM | Miscellaneous data. |
| Library | SLB | Library data from the USACE AGC TOI Library, as described by MR-201424 Munitions Classification Library Update and Expansion |
Dynamic Data Types
| Modelled Data | DMD | Modelled or calculated target of interest (TOI) response data TOI (typically forward modelled). |
| Function Test | DFT | Data from the sensor function test with the standard test item in the cradle. The database structure is an identical structure to SFT. |
| Background Measurement | DBG | Background measurement at a non-anomalous location. |
| Quality Control (IVS) | DQC | Data collected over emplaced instrument verification strip (IVS) targets for quality control purposes. |
| Dynamic Anomaly Measurement | DAM | Dynamic survey measurement for detection and classification of potential targets of interest. |
| Seeded | DSD | Survey data that has been (synthetically) seeded. Calculated (forward modelled) targets of interest (TOI) responses have been added to the original dataset. |
| Test Pit / Stand Measurement | DTP | Test pit or test stand data. |
| Spin Test | DSP | Spin test. |
| Miscellaneous | DXM | Miscellaneous data. |
