Inversion QC
Use the Inversion QC option (Geosoft.uxo.gxnet.dll(Geosoft.GX.UXO.UxaInversionQc;Run)*) from the menu AGC Expert User > Static Data Inversion to determine if the inversion results and the sources are valid. For example, if you are able to model the data and if the solution is reasonably beneath the array.
Inversion QC dialog options
Master Database | |
Master database prefix | Select the optional master database prefix. Script Parameter: UXANALYZE.MASTER_IMPORT_DBPREFIX |
Group | Select the group in the master database. Default group name is FlagList. Script Parameter: UXANALYZE. MASTER_GROUP |
Databases | |
Prefix | Select the databases prefix. Script Parameter: UXANALYZE. DBPREFIX |
Target group | Select the target group from the target database. Script Parameter: UXANALYZE.TARGETGROUP |
Source group | Select the source group from the source database. Script Parameter: UXANALYZE.SOURCEGROUP |
Mask channel | Select the mask channel to select which sources the QC metrics are calculated. Script Parameter: UXANALYZE.TARGETMASK |
Low gate | Select from the list the low time gate to be used in the Inversion QC process. Defaults to the low gate used in Dynamic Inversion or to the gate with the first valid time (UXA_GateFirstValidTime). You may choose to break out a different gate by using the Calculate Size and Decay Channels tool. Script Parameter: UXANALYZE.LOGATE |
Decay gate | Select from the list the decay time gate to be used in the Inversion QC process to determine the decay for an item. The default value for the decay gate depends on the sensor and is read from the UXA.config file. Defaults to the value used in Calculate Size and Decay Channels, if the tool has been executed. Script Parameter: UXANALYZE.THRESHOLDGATE |
Parameters | |
Fit coherence | Specify the minimum acceptable fit coherence Default value is 0.8. Script Parameter: UXANALYZE. MIN_FIT_COHERENCE |
Difference - array position & inverted location (m) | Specify the maximum distance between the array position and the inverted location, in metres. Default value is 0.4. Script Parameter: UXANALYZE.MAX_DIFF_ARRAY_INV_LOCATION |
Difference - array position & flag location (m) | Specify the maximum distance between the array position and the flag location, in metres. Default value is 0.75. Script Parameter: UXANALYZE.MAX_DIFF_ARRAY_FLAG_LOCATION |
Difference - flag location & inverted location (m) | Specify the maximum distance between in the flag location and the inverted location, in metres. Default value is 0.6. Script Parameter: UXANALYZE. MAX_DIFF_FLAG_INV_LOCATION |
Minimum size | Specify the minimum size. Default value is -1.5. Script Parameter: UXANALYZE.MIN_SIZE |
Maximum decay | Specify the maximum decay; any sources (values in the channel 'UXA_Decay' at the decay gate) that have a decay greater than this value would fail. Default value is 1. Script Parameter: UXANALYZE.MAX_DECAY |
The Inversion QC tool calculates several metrics to determine if the inversion results, the sources, are valid.
In the source database, a channel named UXA_QC_Inv is created. This channel will contain a 1 for sources that pass, or a dummy (*) for those that fail. The UXA_Mask_QC channel will also be updated to deselect, sources that fail will be set to dummy, so they are not included in subsequent processing.
In the target database, similarly, a channel named UXA_QC_Inv is created. This channel will contain a 1 (or pass) if there is at least one source that passes for that measurement. The UXA_Mask_QC channel will be update and set to dummy (*) when all source for that measurement fail, so the measurement is not included in subsequent processing.
Master Database
In the master database (if selected), the channel UXA_QC_Inv is created (if it doesn't exist).
The channel is populated based on the content of UXA_QC_Inv channel in the target database: it will be set to dummy if all the records in the target database with the same geo ID and flag ID are dummy.
