Create Polarization Plots with Library Match
Use the Create Polarization Plots with Library Match option (Geosoft.uxo.gxnet.dll(Geosoft.GX.UXO.UxaPolarizationMap;Run)*) from the AGC Expert User > Source and Library Management menu to create a polarization plot of the targets against a master signature library.
Create Polarization Plot with Library dialog options
Library Database
Name
Select the signature library.
This library is a Geosoft database containing a variety of known munitions.
Script Parameter:UXAPOLARIZATIONMAP.SIGNATURE_LIBRARY_DATABASE
Group
Select the library group.
Script Parameter:UXAPOLARIZATIONMAP.LIBRARY_DATABASE_GROUP
Item description channel
Select the item description (ID) channel in the signature library.
Script Parameter:UXAPOLARIZATIONMAP.ITEM_DESCRIPTION_CHANNEL
Source Database
Name
Select the source database.
Script Parameter:UXAPOLARIZATIONMAP.TARGET_DATABASE_NAME
Group
Select the source group.
Script Parameter:UXAPOLARIZATIONMAP.TARGET_DATABASE_GROUP
ID channel
Select the ID channel.
Script Parameter:UXAPOLARIZATIONMAP.TARGET_DATABASE_ID
Mask channel
Select the mask channel.
Script Parameter:UXAPOLARIZATIONMAP.TARGET_DATABASE_MASK
Match Criteria
Display mode
Select the display mode as:
  • Library match - single criteria: When selected, the polarization plot is created for one set of library match channels.
  • Library match - multiple criteria: When selected, the polarization is created for up to three sets of library match channels.
  • Library match - n-dipole sources: When selected, the polarization plot is created for up to three sets of library match channels and up to six sources.
  • Self match (cluster): When selected, the polarization plot is created for a set of library match channels and a set of target match channels.
  • IVS: When selected, the polarization plot is created for one set of library match channels. This plot will look the same as the Self match (cluster) option where the cluster polarizations would consist of the targets with the same flag ID.
Script Parameter:UXAPOLARIZATIONMAP.CONFIDENCE_DISPLAY_MODE
Library match channels are the result of Perform Library Match tool. Depending on the Display mode, up to three sets of library match channels can be selected for the output polarization plot.
Suffix
Select a channel from the dropdown list.
In order to populate the list, the GX looks for the array channels starting from UXA_LmStat_ and UXA_LmID_, then it removes UXA_LmStat_ and UXA_LmID_ from the names and add the remaining part to the list.
Script Parameter:
  • UXAPOLARIZATIONMAP.LM_SUFFIX1
  • UXAPOLARIZATIONMAP.LM_SUFFIX2
  • UXAPOLARIZATIONMAP.LM_SUFFIX3
Match Statistics
When the suffix is selected, the match statistics channel name is formed as UXA_LmStat_[SUFFIX].
This channel is a numerical channel and represents the degree of match between the target and items in the library database.
Match ID
When the suffix is selected, the match statistics channel name is formed as UXA_LmID_[SUFFIX].
This channel is a string channel and represents the matching items in the library database.
Polarization Display
Target selection
Polarization plots can be created in a Batch or Interactive mode.
In Batch mode, the polarization plot is created for all the targets in the target database, whereas in Interactive mode, only the plot associated with the selected target ID is created.
Script Parameter:UXAPOLARIZATIONMAP.TARGET_SELECTTION
ID
Select the target ID. This entry is enabled only in the Interactive mode.
Script Parameter:UXAPOLARIZATIONMAP.TARGET_SELECTION_ID
Plot prefix
Enter the plot name prefix, which will be combined with target ID to create the polarization plot name: Prefix_ID.png.
Default folder to save the polarization plots is: UXANALYZE_wrk\pol_maps.
Script Parameter:UXAPOLARIZATIONMAP.MAP_PREFIX
Plot name
This shows the complete plot name.
Plot type
Determines the content of the output plot. One of the following three options can be selected:
  • No comparison– plots the target betas only
  • Closes matches– plots the targets betas against the betas for up to 6 closest matches in the library
  • Munition type– plots the target betas against the betas for up to 6 items in the library specified by a keyword
  • Each option has an additional entry to be filled, except the first one.
  • The first and last options are disabled when Multiple library matches, multiple sources is chosen as the Display mode.
  • Script Parameter:UXAPOLARIZATIONMAP.MAP_TYPE
    Self Match Threshold
    Enter the self match threshold, which is used to pick the matching targets in the target database. Targets with a metric exceeding the threshold along with the current target will form a cluster.
    This field is available when Self match (cluster) is chosen as the Display mode.
    Script Parameter:UXAPOLARIZATIONMAP.MATCH_THRESHOLD
    Axis
    Determines the scale options for the axes. One of the following two options can be selected:
    • Auto scale– uses the current data to automatically scale both axes
    • Fixed scale– allows the user to manually define the minimum and maximum values of both the X axis (time) and the Y axis (beta)
      This is the default selection.
      Default values for minimum beta and maximum beta are 0.0005 and 1000, respectively.
  • When using the fixed scale option, youmay leave any of the minimum,maximum-X,Y fields blank to let the tool decide the best scaling for a particular field. Leaving all fields blank will yield the same results as the auto scale option.
  • You can use the calculate buttons on each of the minimum,maximum-X,Y fields to get the actual minimum or maximum values in the data represented by X and Y. This data depends on the time channel (for the X axis) and the target ID channel (for the Y axis). Note that the target selection must either have an ID defined or be set to batch mode in order to calculate a minimum or maximum Y.
  • Script Parameters:UXAPOLARIZATIONMAP.AXIS_SCALE, UXAPOLARIZATIONMAP.MINX, UXAPOLARIZATIONMAP.MINY, UXAPOLARIZATIONMAP.MAXX, UXAPOLARIZATIONMAP.MAXY
    Normalize secondary and tertiary to primary
    When selected, the output plot shows the polarization ratios:
    • Curve1: Beta1
    • Curve2: Beta2 / Beta1
    • Curve3: Beta3 / Beta1
    This would make it easier for users to understand why some item have a good or poor library match.
    Script Parameter:UXAPOLARIZATIONMAP.NORMALIZED
    [Run]
    Generates and saves the polarization plots for the selected target or all the targets in the target database depending on the Target selection method.
    Shows the polarization plot if Interactive mode is selected.
    This classification routine reads in a library containing clutter and targets of interest for the site and compares them to the fit results in the target database. The output plot is a combination of polarizability plots. This tool works on one target at a time. A target is selected from the list, and then the target fit results and the entire library are passed to an IDL routine, which calculates a confidence metric for each library item. The results are returned and populated into the target database as array channels.
    The user has the option to:
    • Display the polarization plot for just the unknown target.
    • Display the polarization plots of the best X number of items in the library with both library item and target polarizations overlaid.
    • Display the polarization plots of one or more ordnance types based on some keyword in the library database, i.e., plot library 60mm ordnance in gray and overlay the target polarizations. The following sample compares an unknown target to the library and shows all the items in the library that correspond to a particular type of UXO.
    The output plot will contain up to 9 polarization plots if the selected target is compared to the signature library. If no comparison is done, the plot will show on polarization plot for the selected target.
