Create Library Overlay
Use the Create Library Overlay option (Geosoft.uxo.gxnet.dll(Geosoft.GX.UXO.UxaCreateOverlay;Run)*) to create a library overlay XY plot with customized post, symbol, size and colour values for masked library items.
UX-Analyze extension:
  • AGC Survey Prep > Prepare Library
  • AGC Static Data > Create a Site Specific Library
  • AGC Expert User > Source and Library Management
Create Library Overlay dialog options
Library Database
Name
Specify the library database name.
Script Parameter: UXANALYZE.LIBRARYGDB
Group
Select the library group.
Script Parameter: UXANALYZE.LIBRARYGROUP
Item description channel
Select the library ID channel.
Script Parameter: UXANALYZE.LIBRARYID
Overlay mask channel
Select the library mask channel.
Script Parameter: UXANALYZE.LIBRARY_OVERLAY_MASK
Post (Type) channel
Select the library post channel.
Script Parameter: UXANALYZE.LIBRARY_OVERLAY_POST
Size channel
Select the library size channel (an array channel is expected).
Script Parameter: UXANALYZE.LIBRARYSIZE
Gate
(next to the Size channel)
Select the gate of the size channel.
This combo box is populated with all the indices, starting at 0, up to the array length of the size channel.
Default value is dictated by the size of the array in the database, which indicates the sensor used. It is 8 for MetalMapper and 14 for TEM2x2x3.
Script Parameter: UXANALYZE.LOGATE
Decay channel
Select the library decay channel (an array channel is expected).
Script Parameter: UXANALYZE.LIBRARYDECAY
Gate
(next to the Decay channel)
Select the gate of the decay channel.
This combo box is populated with all the indices, starting at 0, up to the array length of the decay channel.
Default value is dictated by the size of the array in the database, which indicates the sensor used. It is 36 for MetalMapper and 71 for TEM2x2x3.
Script Parameter: UXANALYZE.THRESHOLDGATE
Posting Attributes
Size
Specify the size (in mm) of the post values. Default is 1.8mm.
Script Parameter:UXANALYZE.LIBRARY_OVERLAY_POST_SIZE
Colour
Specify the colour of the post values.
Script Parameter:UXANALYZE.LIBRARY_OVERLAY_POST_COLOR
Horizontal offset
Specify the horizontal offset (in mm) of the post values. Default is -3.0mm.
Script Parameter:UXANALYZE.LIBRARY_OVERLAY_POST_HOFFSET
Vertical offset
Specify the vertical offset (in mm) of the post values. Default is 1.5mm.
Script Parameter:UXANALYZE.LIBRARY_OVERLAY_POST_VOFFSET
Extents
Size - Min
Specify the min (in mm) of the size value. Default -2.0.
Script Parameter:UXANALYZE.MINSIZEOVERLAY
Size - Max
Specify the max (in mm) of the size value. Default 3.0.
Script Parameter:UXANALYZE.MAXSIZEOVERLAY
Decay - Min
Specify the min (in mm) of the decay value. Default 0.0.
Script Parameter:UXANALYZE.MINDECAYOVERLAY
Decay - Max
Specify the max (in mm) of the decay value. Default 0.1
Script Parameter:UXANALYZE.MAXDECAYOVERLAY
Symbol Attributes
Data Grid View
This data grid view is populated with all items in the database that match the group and mask channel specified. The Item Description and Type columns match the values in the Item description and Post (Type) channels and are read-only columns, the Symbol, Size (mm), Colour, and Symbol Weight columns may be specified by you.
Script Parameters:
  • UXANALYZE.N_ITEMS_SYMBOL_ATTRIBUTES (number of rows in the data grid view)
  • UXANALYZE.SYMBOL_ATTRIBUTES_ITEM_DESCRIPTION_#
  • UXANALYZE.SYMBOL_ATTRIBUTES_SYMBOL_#
  • s
  • UXANALYZE.SYMBOL_ATTRIBUTES_SIZE_#
  • UXANALYZE.SYMBOL_ATTRIBUTES_COLOR_#
  • UXANALYZE.SYMBOL_ATTRIBUTES_WEIGHT_#
  • UXANALYZE.SYMBOL_ATTRIBUTES_TYPE_#
# is the index of the item in the data grid view, up to N_ITEMS_SYMBOL_ATTRIBUTES
Fill symbols
When selected, the plotted symbols have the same fill colour as the border, otherwise there is no fill.
Default value is not selected.
ss Script Parameter: UXANALYZE.FILL_LIBRARY_SYMBOL
[Load Symbols]
When selected, the symbol attributes will be loaded from a CSV file, which has the following header and sample row:
CODE,LABEL,DESCRIPTION,COLOR,BACK_COLOR,SYMBFONT,SYMBNUM,SYMBROT,SYMBSCL
105mm,105mm,,C127M127Y63,N,"symbols(GFN,MEDIUM)",27,,3
5 of the columns map to the columns in Symbol attributes grid:
CSV ColumnSymbol attributes grid column
CODEType
SYMBNUMSymbol
SYMBSCLSize (mm)
COLORColour
SYMBFONT
Only the second part of the font, MEDIUM in the sample above, is used.
Symbol Weight
For each record in the CSV file, the GX will update the attributes for the items in the Symbol attributes grid that have the same type value.
Output
Overlay name
Specify the name of the overlay to be created.
The overlay files (.map, .geosoft_overlay, .geosoft_template) will be created and saved in the %USERPROFILE%\Documents\Geosoft\Desktop Applications \etc folder. If this overlay already exists, a message will prompt you to overwrite the current overlay or enter a new name.
Script Parameter:UXANALYZE.LIBRARY_OVERLAY_NAME
When successfully run, this GX creates four files using the specified overlay name plus the following extensions: .map, .geosoft_overlay, .geosoft_template, and.uxa_overlay. While the .map file is a standardGeosoft map file, the .geosoft_overlay and .geosoft_template files may be used with the Scatter Analysis tool in Oasis montaj (under Database Tools / Geostatistics Toolkit). However, because the Horizontal and Vertical fields (in the Scatter Analysis tool) do not accept array channels, the .geosoft_overlay and .geosoft_template parameters specify the name of the Size and Decay channels followed by the corresponding gate number selected when creating the overlay (as the Horizontal and Vertical fields, respectively). Note that these channels must either be created with a different tool or manually in order to be used with Scatter Analysis.
  • When using a script file to run the Create Library Overlay, the overlay map will not be displayed.
  • The newest addition to the output files, .uxa_overlay, contains the symbol and posting information that will be used in the Create Size and Decay Plot GX.
    The following shows an example of one target from the *.uxa_overlay file:
    <?xml version="1.0" encoding="utf-8"?>
    <attributes>
        <symbols fill="false">
    	<symbol symbolX="0.447171590192031"
    	symbolY="0.0303270371650022"
    	symbolWeight="bold"
    	symbolColor="33619967"
    	symbolSize="1"
    	symbolType="+"
    	text="Small ISO80_BP120724_TP33s" />
        </symbols>
        <posting
    	verticalOffset="0"
    	horizontalOffset="0.03"
    	colour="33554432"
    	size="2" />
    </attributes>
