Create Interactive Image Viewer
Use the Create Interactive Image Viewer option (Geosoft.uxo.gxnet.dll(Geosoft.GX.UXO.UxaLaunchInteractiveImageView;Run)*) to interactively view an image associated with a source, by clicking on the source in a source database.
UX-Analyze extension:
  • AGC Dynamic Data > Review Classification > Interactive Image Viewers
  • AGC Static Data > Review Classification > Interactive Image Viewers
  • AGC Expert User > Source Classification and Review > Interactive Image Viewers
Create Interactive Image Viewer dialog options
Source Database
Name
Specify the source database name.
Script Parameter: UXANALYZE.SOURCEGDB
Group
Select the source group.
Script Parameter: UXANALYZE.SOURCEGROUP
ID channel
Select the source ID channel.
Script Parameter: UXANALYZE.TARGETID
Source Image
Folder
Specify an image folder.
This should be an existing folder.
Script Parameter: UXANALYZE.TARGET_IMAGE_FOLDER
Prefix
Specify the file prefix, which is used to filter out the files in the image folder.
Script Parameter: UXANALYZE.TARGET_IMAGE_PREFIX
Suffix
Specify the file suffix, which is used to filter out the files in the image folder.
Script Parameter: UXANALYZE.TARGET_IMAGE_SUFFIX
Format
Select the image format from the list of PNG, JPEG, Bitmap, TIFF, and PCX.
The default is PNG.
Script Parameter: UXANALYZE.TARGET_IMAGE_FORMAT
Interactive Image View dialog options
[Disable] / [Enable]
This button enables the user to disable/enable the image finding and displaying process.
Default status is enabled if the source and image information are provided.
[Setting]
When selected the Source and Image Parameters dialog will be displayed.
The Interactive Image View dialog can be docked within the Oasis montaj workspace, or it can be moved out. The tool is enabled by default.
As soon as a cell is clicked in the source database, the Interactive Image View tool determines the associated source ID, and looks to find its associated image from the image folder. If found, the image is displayed as a map. The map is named _source_image_setting[X].map, where [X] is the Interactive Image View dialog number.
  • Clicking on a cell that is already highlighted in the database does not trigger the Interactive Image View dialog. You need to click on a different cell within that row or other rows.
  • The tool can be disabled by clicking the [Disable] button. You can open up to ten Interactive Image View dialogs at the same time.
