Load Viewer Parameters
Use the Load Viewer Parameters option (Geosoft.uxo.gxnet.dll(Geosoft.GX.UXO.UxaLoadViews;Run)*) to load or create one or more viewers from a previously saved file.
UX-Analyze extension:
  • AGC Dynamic Data > Review Classification > Interactive Image Viewers
  • AGC Static Data > Review Classification > Interactive Image Viewers
  • AGC Expert User > Source Classification and Review > Interactive Image Viewers
Load Viewer Parameters dialog options
Input view file name
Select a .imgview file containing previously saved image viewers.
Script Parameter: UXANALYZE.FILENAME
