Calculate Forward Model
Use the Calculate Forward Model option (Geosoft.uxo.gxnet.dll(Geosoft.GX.UXO.UxaCalculateForwardModel;Run)*) to calculate a forward model reference response of static or dynamic (multi-shot) measurements. You can configure up to six TOI items and calculate their responses for a specified sensor configuration.
UX-Analyze extension:
- AGC Survey Prep
- AGC Expert User
Calculate Forward Model dialog options
| Sensor | |||||||||||||||||
| Model | Select the sensor model (type). The values are read from the sensor configuration table; refer to the Application Notes below. Script Parameter: UXACALCFRW.MODEL | ||||||||||||||||
| Configuration | Select a configuration for the selected sensor model. The values are read from the sensor configuration table; refer to the Application Notes below. If the Model field is set to "All", the Configuration list will contain the configurations for all the sensor models. Script Parameter: UXACALCFRW.SENSOR | ||||||||||||||||
| Height above ground (m) | Specify the height of the sensor above the ground surface, i.e., the "Height of Transmitter Assembly above ground". This is used to determine the height of the receiver coils above the ground, which is the sum of "Height of Transmitter Assembly above ground" and "Height of Z Coil above the Transmitter Assembly". For example:
 The height should be between 0 and 2 metres. Script Parameter: UXACALCFRW.HEIGHTABV | ||||||||||||||||
| Survey | |||||||||||||||||
| Survey type |
| Line spacing (m) | Specify a value between 0.00 and 10.00 for the line spacing. The default is 0.8 times the maximum of the transmitter coils LengthX or sum of LengthXs. Script Parameter: UXACALCFRW.LINESPCN | ||||||||||||||||
| Station spacing (m) | Specify a value between 0.00 and 10.00 for the sample spacing along the line. The default is 0.2 times the maximum of the transmitter coils LengthY or sum of LengthYs. Script Parameter: UXACALCFRW.STATIONSPCN | ||||||||||||||||
| Data chip size | Specify the data chip size. This is the window over which the forward model will be calculated:
 This window bounds the locations where you will be able to place the TOI. An additional two lines are added beyond the data chip extent to limit edge effects.  | ||||||||||||||||
| Library Database | |||||||||||||||||
| Name | Use the browse button or the drop-down arrow to select the signature library database. The library database must contain the following channels:
 A warning tooltip will be displayed if the pulse length of the library data and  the sensor configuration differ by more than 15%. Script Parameter: UXACALCFRW.LIBRARYDB | ||||||||||||||||
| Group | Select the TOI library group. Default: the first group (line) in the selected library database. Script Parameter:UXACALCFRW.LIBRARYGRP | ||||||||||||||||
| Mask | Select a mask channel. When this channel is set to 1, the action will be performed on the data entry; if the value is set to 0 or dummy (*), the corresponding data entry will be ignored. Script Parameter: UXACALCFRW.LIBRARYMASK | ||||||||||||||||
| TOI class channel | From the library list, select the channel that contains the TOI types. This channel will filter the TOI list, making it easier to find and select the TOI items. Default: UXA_Class (if the channel exists in the database) Script Parameter: UXACALCFRW.LIBRARYCLASS | ||||||||||||||||
| TOI description channel | Select the channel that contains the name or description of the items. This channel must contain unique values for each library item – typically this is the Library ID channel. Default: UXA_LIBRARY_ID (if the channel exists in the database) Script Parameter: UXACALCFRW.LIBRARYDESCRIPTION | ||||||||||||||||
| Output database prefix | Specify the prefix for the output databases (see the Application Notes below for further details). The drop-down list is populated with the prefixes of the static/dynamic databases that reside in the current project; the list is filtered based on the Survey type selection. Selecting an existing prefix will run the tool on the databases corresponding to the selected prefix; no new databases will be created. Script Parameter: UXACALCFRW.OUTPUTPREFIX | ||||||||||||||||
| Group | Specify the name that will be applied to the groups generated in the output databases:
 You can also select an existing group available within the databases, from prior runs: the drop-down list is populated with the groups associated with your current Output database prefix selection. Script Parameter: UXACALCFRW.OUTPUTGROUPPREFIX | ||||||||||||||||
| TOI | |||||||||||||||||
| TOI Items | Configure up to six items | ||||||||||||||||
| Class | You can select a specific TOI type from the list or keep the default entry "All". The list is populated with the values of the TOI class channel. Script Parameter: UXACALCFRW_TOI_#.CLASSTOI | ||||||||||||||||
| Item | Select the TOI name/description from the list. The list is filtered based on the selected Class entry. If "All" is selected, the list will contain all the entries from the description channel. Default: the first entry in the list Script Parameter: UXACALCFRW_TOI_#.ITEM | ||||||||||||||||
| X Offset (m) | Specify the X coordinate of the middle point of the target window (± 0.5 times the chip size across line). Default: 0.00 Script Parameter: UXACALCFRW_TOI_#.X_OFFSET | ||||||||||||||||
| Y Offset (m) | Specify the Y coordinate of the middle point of the target window (± 0.5 times the chip size along line). Default: 0.00 Script Parameter: UXACALCFRW_TOI_#.Y_OFFSET | ||||||||||||||||
| Depth (m) | Enter the TOI depth below the ground surface. The depth should be between 0 and 10 meters. Default value: 0.01 Script Parameter: UXACALCFRW_TOI_#.DEPTH | ||||||||||||||||
| Inclination | Select an option for the item's inclination:
 Default: Horizontal Script Parameter: UXACALCFRW_TOI_#.INCLINATION [0: Horizontal (default); 45: Inclined 45; 90: Vertical] | ||||||||||||||||
| Declination /azimuth | Select an option for the declination of the item:
 Default: In-line Disabled when the Inclination is set to "Vertical". Script Parameter: UXACALCFRW_TOI_#.DECLINATION [0: In-line (default); 45: Inclined 45; 90: Cross-line] | ||||||||||||||||
| [Restore Defaults] | Click on the Restore Defaults button to return all of the parameters to their default values. | ||||||||||||||||
The tool will generate a TOI reference database of the forwarded model response of the selected item(s). This can help you better understand the theoretical response you can expect to measure for TOI. In addition, for static data this can be used with the Background Location Validation Test when trying to determine suitable background locations and the detectability of a TOI at your site.
The response is first determined for each configured TOI item. Then, the combined response of the TOI items is calculated.
When calculating the response, to help prevent two items occupying the same space, the position (X offset, Y offset and Depth), orientation (Inclination and Declination), and size of the items (the UXA_Dimensions field in the library database) are checked, and a warning is issued if two or more items do occupy the same space.
The following dynamic (DMD) /static (SMD) databases are created:
- [DBPREFIX]_DMD/SMD_Data: contains the calculated response data.
- [DBPREFIX]_DMD/SMD_Source: contains a copy of the polarizabilities and other information from the library. An entry for each forward model and TOI item is created. The channel UXA_Description is populated with the individual TOI items descriptions.
- [DBPREFIX]_DMD/SMD_Target: contains any target or parameters information. A single entry is created for each run. The channel UXA_Identifcation is populated with compounded UXA_Description values and prefixed with the UXA_Target_ID values for the static option. The channel UXA_NumTOIItem records the number of TOI items.
- [DBPREFIX]_DMD_Parameter - contains information for each survey line.
- [DBPREFIX]_DMD_Located - contains information for each survey line and receiver version number.
The dynamic option does not support multiple models/runs in a single set of databases: the DMD databases will be overwritten when the GX is executed against the same output databases.
Sensor Table
The sensor configuration parameters are read from the sensor table: the default sensor table file "SensorTableAdvanced.xml" is in the "C:\Program Files\Geosoft\Desktop Applications \etc" folder.
To add new sensors or configurations to the table, you can use the Add Sensor Configuration tool. The edited file is then saved in the "%USERPROFILE%\Documents\Geosoft\Desktop Applications \etc" folder.
UX-Analyze Configuration File
The configuration file contains various default or standard settings for the tools. It is recommended that you edit this file only if directed by Support. The file, "uxa.config", is in the "C:\Program Files\Geosoft\Desktop Applications \etc" folder.
