Identify Source Clusters
Use the Identify Source Clusters option (Geosoft.uxo.gxnet.dll(Geosoft.GX.UXO.UxaIdentifyUnexplainedItems;Run)*) to flag the unexplained ground truth items in the source database.
UX-Analyze extension:
  • AGC Dynamic Data > Review Classification
  • AGC Static Data > Review Classification
  • AGC Expert User > Source and Library Management
Identify Source Clusters dialog options
Source Database
Name
Specify the source database name.
Script Parameter:UXANALYZE.SOURCEGDB
Group
Select the source group name.
Script Parameter:UXANALYZE.SOURCEGROUP
ID channel
Select the source ID channel name.
Script Parameter:UXANALYZE.TARGETID
Mask channel
Select the source mask channel name.
Script Parameter:UXANALYZE.TARGETMASK
Size channel
Select the source size channel name.
Default value is UXA_SIZE.
Script Parameter:UXANALYZE.TARGETSIZE
Type channel
Select the type channel name, which is a string channel.
If this channel is blank, all the sources in the group are matched against each other. If the channel is selected, the sources are grouped based on the ground truth values, then the matching is done.
Script Parameter:UXANALYZE.TARGETGROUNDTRUTH
Gates
Select the low and high gates, which will be passed to Perform Library Match that is executed in the background.
Default value for low gate is 14 in case of TEM2x2x3 and 8 for other sensors.
Default value for high gate is the maximum number of gates minus one.
Script Parameter:
  • UXANALYZE.LOGATE
  • UXANALYZE.HIGATE
Library Database
Name
Specify the signature library database name.
Library database is optional, and when it is blank, Group, Item description channel, and Library match metric will be disabled.
Script Parameter:UXANALYZE.LIBRARYGDB
Group
Select the signature library group name.
Script Parameter:UXANALYZE.LIBRARYGROUP
Select the item description channel name.
Script Parameter:UXANALYZE.LIBRARYID
Specify the library match metric, which is used to find the library items matching the source.
Default value is 0.95.
Script Parameter:UXANALYZE.LIBRARY_THRESHOLD
Source Cluster Output
Cluster suffix
Specify the cluster suffix.
When the dialog is run, a unique cluster ID is assigned to all the sources in that cluster. Starting cluster ID is 1.
Cluster ID channel name is: UXA)CLUSTER_ID_[SUFFIX].
In order to specify the main item in each cluster, UXA_UNIQUE_SIGNATURE_[SUFFIX] channel is also created. This channel is dummy for all the records except the main item in each cluster, which is assigned the cluster ID.
Script Parameter:UXANALYZE.TARGETCLUSTER_SUFFIX
Minimum match metric
Specify the cluster threshold, which is used to find the sources that are similar.
Script Parameter:UXANALYZE.MATCH_THRESHOLD
Minimum number of matches
Select the minimum number of matches (items) to define a cluster.
Default value is 3.
Script Parameter:UXANALYZE.MIN_NO_OF_MATCHES
Minimum polarization amplitude
Specify the minimum polarization amplitude, which will be passed to Perform Library Match that is executed in the background.
Default value is 0.001.
Script Parameter:UXANALYZE.MIN_BETA_AMP
Below are the processing steps used to flag the unexplained ground truth items in the source database.
Processing Steps
  • Sort the sources based on low gate of size channel.
  • Mask out the sources smaller than a minimum size, read from "uxa.config", for more information refer to uxa.config section below.
  • Run library match with 111 weights, and mask out items with a metric exceeding the Library threshold.
  • Mask out any sources without a valid library match, which is specified by -9999.
  • In order to speed up the process, put the sources into different bins based on the maximum number of sources in each bin. Each bin will overlap the adjacent bins by a percentage of the number of sources in each bin. The number of sources in each bin and the percentage overlap are read from "uxa.config".
    However, if you select a ground truth channel, the sources are put into bins based on the ground truth values (and no overlapping between bins occur).
  • Run self-match with 111 weights for each bin until all sources are masked out.
Output Files
The following channels are created:
UXA_CLUSTER_ID_[SUFFIX]
uxa.config
The minimum size and binning information can be found in "uxa.config", which can be located in C:\Program Files\Geosoft\Desktop Applications \etc folder:
<manageLibrary> <targetSize min="-1" /> <targetBin size="500" overlap="20" /> </manageLibrary>
