Identify Used Library Items
Use the Identify Used Library Items option (Geosoft.uxo.gxnet.dll(Geosoft.GX.UXO.UxaIdentifyUsedItems;Run)*) from the menu AGC Expert User > Source and Library Management to flag library signatures that are matched against the Perform Library Match process.
Identify Used Library Items dialog options
Source Database
Name
Specify the source database name.
Script Parameter:UXANALYZE.SOURCEGDB
Group
Select the source group name.
Script Parameter:UXANALYZE.SOURCEGROUP
ID channel
Select the source ID channel name.
Script Parameter:UXANALYZE.TARGETID
Mask channel
Select the source mask channel name.
Script Parameter:UXANALYZE.TARGETMASK
Size channel
Select the source size channel name.
Default value is UXA_SIZE.
Script Parameter:UXANALYZE.TARGETSIZE
Gates
Select the low and high gates, which will be passed to Perform Library Match that is executed in the background.
Default value for low gate is 14 in case of TEM2x2x3 and 8 for other sensors.
Default value for high gate is the maximum number of gates minus one.
Script Parameter:
  • UXANALYZE.LOGATE
  • UXANALYZE.HIGATE
Library Database
Name
Specify the signature library database name.
Script Parameter:UXANALYZE.LIBRARYGDB
Group
Select the signature library group name.
Script Parameter:UXANALYZE.LIBRARYGROUP
Item description channel
Select the item description channel name.
Script Parameter:UXANALYZE.LIBRARYID
Output mask channel
Specify the mask channel name, which reflects the flagged library signatures. If the mask channel doesn't exist, it will be created.
Script Parameter:UXANALYZE.LIBRARYMASK
Output group
Specify the group name, in which the flagged library signatures will be saved.
Script Parameter:UXANALYZE.LIBRARYGROUP2
Library match metric
Specify the library match metric, which is used to find the library items matching the source.
Default value is 0.95.
Script Parameter:UXANALYZE.LIBRARY_THRESHOLD
Source Cluster Output
Minimum polarization amplitude
Specify the minimum polarization amplitude, which will be passed to Perform Library Match that is executed in the background.
Default value is 0.001.
Script Parameter:UXANALYZE.MIN_BETA_AMP
Below are the processing steps used to flag library signatures that are matched against the Perform Library Match process.
Processing Steps
  • Sort the sources based on low gate of size channel.
  • Mask out the sources smaller than a minimum size, read from "uxa.config", for more information refer to uxa.config section below.
  • Run library match with 111 weights, and mask out items with a metric exceeding the Library threshold.
  • Mask out any sources without a valid library match, which is specified by -9999.
  • Create and populate the output group and the optional mask channel in the library database.
Output Files
At the end of the process a new output Group and Mask channel is created in the Library database.
