Pick Target Locations from Grids
Use the Pick Target Locations from Grids option (Geosoft.uxo.gxnet.dll(Geosoft.GX.UXO.UxaPickTargetLocations;Run)*) to pick the peak locations from the Coherence Anomaly and/or Amplitude grids using the Blakely peak picking method. The threshold for Model Coherence grid is established using the Determine Coherence Anomaly Threshold tool. The results will be saved into the target database.
UX-Analyze extension:
  • AGC Dynamic Data
  • AGC Expert User > Dynamic Data Target Picking
Pick Target Locations from Grids from dialog options
Database prefix
Select the sensor (data) database prefix.
Script Parameter: UXANALYZE.DYN_PICK_DBPREFIX
Anomaly Grids
Model coherence
Select the model coherence grid name.
  • Model coherence grid should be entered if Amplitude grid is blank.
  • Script Parameter: UXANALYZE.DYN_PICK_COH_GRID
    Threshold
    Specify a grid value below which you want peaks to be removed from the list.
    You can determine a reasonable threshold by using Determining Coherence Threshold tool.
    Script Parameter: UXANALYZE.DYN_PICK_COH_THRESHOLD
    Amplitude
    Select the amplitude grid name.
  • Amplitude grid should be entered if Model coherence grid is blank.
  • Script Parameter: UXANALYZE.DYN_PICK_AMP_GRID
    Threshold
    Script Parameter: UXANALYZE.DYN_PICK_AMP_THRESHOLD
    Survey Target Database
    Name
    Displays the name of the target database, which will be created if it doesn't exist.
    Group
    Specify the target group name. The group will be created if it doesn't exist.
    Script Parameter: UXANALYZE.TARGETGROUP
    Id channel
    Specify the target id channel name. The channel will be created if it doesn't exist.
    Script Parameter: UXANALYZE.TARGETID
    Mask channel
    Specify the target mask channel name. The channel will be created if it doesn't exist.
    Script Parameter: UXANALYZE.TARGETMASK
    [More]
    Anomaly merge distance (m)
    Specify the anomaly merge distance. If a Model coherence pick is within this distance from an Amplitude pick, discard the Amplitude pick, set the UXA_PeakType channel to "Both".
    Default value is 0.2.
    Script Parameter: UXANALYZE.DYN_PICK_MERGE_DISTANCE
    No of passes of smoothing filter
    Specify the number of passes of smoothing (Hanning) filter to apply to the grid so that low amplitude, high frequency ‘noise’ targets will not be picked. The grid will not be smoothed if you enter 0 (zero) or leave the entry blank. More filter passes tend to reduce the number of peaks found. The default is 0.
    The system applies 9-point (3x3) Hanning smoothing filter to the grid, if smoothing is desired. The coefficients of the filter are:
    0.06 0.10 0.06
    0.10 0.36 0.10
    0.06 0.10 0.06
    Script Parameter:
    • UXANALYZE.DYN_PICK_COH_NPASSES
    • UXANALYZE.DYN_PICK_AMP_NPASSES
    Level of peak detection
    The Blakely method is used to find peaks in a grid. For each grid cell, the GX compares its value with the values of its eight (8) nearest grid cells in four directions (along the row, along the column, and along both diagonals). There are four sensitivity levels which may be used to determine whether a grid cell will be selected as a peak:
    Normal (4) - grid values in all of the nearest grid cells are lower
    More peaks (3) - grid values in any three directions are lower
    Even more peaks (2) - grid values in any two directions are lower
    All ridge peaks (1) - grid values in one direction are lower
    Selecting Normal (4) (default) finds fewer peaks. To find all ridges, use All ridge peaks (1) option.
    Script Parameter:
    • UXANALYZE.DYN_PICK_COH_LEVEL
    • UXANALYZE.DYN_PICK_AMP_LEVEL
    The output channels saved into the target database are: UXA_Flag_X, UXA_Flag_Y, UXA_Target_Id, UXA_Mask, UXA_Mask_All, UXA_ModCoh_Value, UXA_Amp_Value, UXA_PeakType and UXASensorHeight.
    UXA_PeakType channel is an indicator to identify the source grid, and can be one of these values: "ModCoh", "Amp", or "Both".
