Auto-fit Mesh to IP Electrodes
Use the Auto-fit Mesh to IP Electrodes dialog to auto fit the mesh to electrodes. The horizontal cell sizes of the mesh can be adjusted so that data positions are as close as possible to cell edges, and a best fit to the electrode configuration selected is obtained (i.e., receivers (Rx), transmitters (Tx), or both receivers and transmitters (Rx and Tx)).
The tool is launched from the Modify IP Mesh Parameters dialog.
Auto-fit Mesh to IP Electrodes dialog options
Electrodes to fit |
Choose from one of the configuration options below:
Nominal cell size in X |
Specify the nominal cell size in the X direction. The default value is determined by the average active cell size. |
Nominal cell size in Y |
Specify the nominal cell size in the Y direction. The default value is determined by the average active cell size. |
[OK] |
Click the button to proceed back to Modify Mesh Parameters. |
To learn more about effective workflows and key concepts, access the
