Modify IP Mesh Parameters
Use the Mesh > Modify option to change the default mesh generated by VOXI.
Modify Mesh Parameters dialog options
Active Volume Cell Size (m)
Horizontal cell increment
Horizontal mesh cells can have a constant or variable cell size. Variable horizontal cell increments are useful for creating areas of high or low resolution in the model based on data or constraint resolution, or desired model resolution. The Constant cell size option is recommended for regularly spaced IP and resistivity surveys.
X,Y,Z
The active volume cell size(s) along each axis. The syntax for defining variable cells is: n1xc1 n2xc2 n3xc3 etc…
Where n is the number of cells and c is the cell size.
  • The variable cell size definition only affects the X & Y coordinates. The cell sizes along the Z coordinate remain the same for all methods.
    [Auto-fit to Electrodes]
    This button appears when you have selected the Variable cell size option and you have added data to the project.
    Click on Auto-fit to Electrodes to launch a tool that allows you to auto fit the mesh to electrodes for receivers (Rx), transmitters (Tx), or both receivers and transmitters (Rx and Tx) configurations. The horizontal cell sizes will be adjusted so that the data positions are as close as possible to cell edges.
  • This function changes the variable cells sizes.
    [Half]
    Half the number or elements (double the resolution) along each major axis.
    [Double]
    Double the number of elements (half the resolution) along each major axis.
    [Reset]
    Restore the previously defined cell sizes.
    Dimensions
    Active
    This read-only entry displays the number of cells along each axis of the area of interest. As the Active volume cell sizes are modified, these figures are recalculated to fully enclose the original mesh volume.
  • The time and cost to perform an inversion is directly related to the dimension of the mesh.
    Padded
    The padded volumes are also displayed for your information.
    Average active cell size
    Displays the average of the X& Y cell sizes. These figures are only of interest if you have opted for the variable horizontal cell size option.
    [More]
    Access advanced mesh settings.
    [OK]
    Proceed to the next step.
    Expanded dialog options
    Depth
    The next six entries pertain to the vertical axis.
    Top of model
    The maximum elevation of the terrain.
    Lin-log transition
    The value along the vertical axis at which to transition to a logarithmic cell expansion.
    Bottom of model
    The bottom of the voxel model along the vertical axis.
    Expansion ratio
    The vertical increment is constant for all cells above the lowest point of the terrain. Below that level, the cell size increases with depth by this factor.
    Padding cells
    Number of padding cells to add to the bottom of the voxel model. Padding is required; see note below.
    Padding expansion ratio
    The intent of the padding cells is to minimize the edge effect in the predicted field. The padded cell size can be expanded when moving away from the active volume, in order to cover a larger area.
    Horizontal Padding
    The next two entries pertain to the horizontal (x and y) axes.
    Cells
    Number of padding cells to add on either side of the x and y axes. Padding is required; see note below.
    Expansion ratio
    The padding cells can be expanded at different rates along the horizontal and vertical axes.
    Active Volume
    The active volume extents are updated to reflect the changes to the above parameters.
    By default, VOXI sets up the mesh according to the area of interest (AoI), the terrain relief, and the user selected horizontal cell size. The VOXI model mesh is a 3D voxel model that represents Earth as a collection of adjacent voxel cells. The mesh is referred to as the Active Volume.
    The Active Volume hangs below the terrain and extends downward to approximately half the minimum dimension of the area of interest, but it should not exceed a reasonable exploration depth. In most cases, exploration becomes uneconomical below a couple of kilometres. Electrical methods generally have a lesser depth of penetration; thus, the default vertical extent of the mesh is set accordingly.
    The Mesh Parameters can be refined to better suit the targeted model. You have the option to define variable horizontal cell sizes within the AoI in order to obtain a better resolution in areas that have a spatially denser coverage. Bear in mind that reducing the cell size increases the size of the mesh, the time required to perform the computation, and the cost of the inversion.
  • Changing the mesh parameters will create a new mesh; all constraints in the model will be resampled to the new mesh.
  • Figure 1: Variable padding cells
    The auto-fit feature calculates the histogram of the X or Y locations. It groups the data in bins of the same size as the horizontal cells. If the number of filled bins in a cardinal direction is less than the initial number of cells in that direction then for each filled bin the average location is determined. A new origin and cell sizes for that direction are then calculated. You might not be able to auto-fit in both directions when the spacing is irregular or much finer along the survey lines. In this case a message is displayed indicating which direction was not auto-fit.
    Figure 2: X cell sizes are adjusted so that electrode locations are located as closely as possible on cell corners
    To learn more about effective workflows and key concepts, access the Seequent Learning Centre Catalogue, select VOXI from the Category list, and explore your learning options.
