Central Integration
Central’s integration with Leapfrog Works lets you work in different project revisions, publish models to the server, view documents and comments and reply to comments. Projects shared within Central can be downloaded and worked on locally in Leapfrog Works. When you have finished working on a project, select the objects you wish to publish to Central and add notes about the revision. New projects can be added to Central by building them from scratch or by uploading an existing project.
Leapfrog Works version 2021.2 is compatible with Central Server versions 4.x.
The rest of this topic describes how to connect to Central from within Leapfrog Works. It is divided into:
- Enabling Central Connectivity
- Switching to Using Seequent ID
- Connecting to Central
- Troubleshooting Connectivity Issues
To learn more about Central, see the Central help.
To enable Central, open the Settings window by clicking on the Leapfrog Works menu. Select Central and tick the box to enable Central. A Central Projects tab will appear in the main window, with a list of Central servers you have access to.
See Central Settings for more information on the other Central-related settings in the Settings window.
If your organisation is switching to using Seequent ID to connect to Central, you may be prompted to change your Central settings when you attempt to connect to your Central server. To do this:
1. Click on the Leapfrog menu and open the Settings window.
2. Click on Central.
3. Enable the Use Seequent ID option.
4. Close the Settings window.
5. Restart Leapfrog.
To access Central, your Central administrator must first add you to the server and assign you permissions for the projects you need to work on. When you receive an email saying you have been granted access to your organisation’s Central server, click the link to open the Central Portal. Follow the prompts to either create a new Seequent ID or sign in using your existing Seequent ID.
The Central servers you have access to via your Seequent ID are shown in the Central dropdown menu:
The stripe under the Central menu shows your connection status. For example, the blue stripe above indicates Leapfrog Works is not connected to a Central server. Here the stripe is green, indicating that Leapfrog Works is connected to a Central server. Clicking on the menu displays more information, including an option to disconnect from the server (
The stripe will be red when there is a connection error and orange if you are connected to a Central server as part of a trial programme.
More information is shown in the Central dropdown when Leapfrog Works is connecting to a server or publishing an update to the server. In this example, Leapfrog Works is in the process of connecting to a server:
Seequent Start checks to see if your network will support the connection of Seequent web-based services to your desktop applications. If you are having trouble with your connection to Central, see Checking Connectivity With Seequent Start.
