Long Sections
A long section is one section or a series of sections that deviates. In Leapfrog Works, a long section can be created from a polyline drawn in the scene or from any line object in the project.
Versions of Leapfrog Works before 2021.1 called long sections “fence sections”.
This topic is divided into:
- Setting Section Parameters
- The Long Section in the Project Tree
- Section Layouts for Long Sections
- Exporting Long Sections
Long sections can be made from a new polyline you draw in the scene or from any existing line object in the project. To create a long section, right-click on the Cross Sections and Contours folder and select New Long Section. The New Long Section window will be displayed:
You can draw the polyline in the scene directly by selecting the New polyline option. You can also use any polyline in the project by selecting the Existing line option and selecting from the lines available in the dropdown list.
The Top and Bottom parameters set the measurements for the top and bottom boundaries of the section. Start value defines the measurement for the start of the reference line. If that is considered the zero point, use 0. If another point is the origin for the line, you might wish to set the Start value for the section as being the offset distance to that origin point. The Line section start and Line section end points make use of this Start value.
Choose Entire line if the long section should span the entire reference line. If only a portion of the line is to be represented by the long section, choose Line section and set the Line section start and Line section end points to choose the portion of the line that is to appear on the long section. Note that these distances along the line include the Start value. For example, if the Start value is 40 and the Line section start is 100, the section will begin 60 units along the reference line.
If the long section is to be a single section along the reference line, untick Multiple sections. For longer lines, it is often useful to tick Multiple sections and divide the line into multiple sections. Use Sub-section length to control how much of the line appears in each section, and Sub-section overlap to specify the amount (if any) on each section that is duplicated on the adjacent section.
Click OK to create the long section. If you chose to create a New polyline, the drawing controls will appear in the scene and you can begin drawing, as described in Drawing in the Scene.
The long section will appear under the Cross Sections and Contours folder and you can edit it by double-clicking on it.
Next, select the objects you wish to evaluate onto the section by right-clicking the long section in the project tree and selecting Evaluations from the popup menu. Add the objects you want to evaluate onto the section to the Selected objects list.
Create a master section layout for the long section by right-clicking the long section in the project tree and selecting New Master Section Layout from the popup menu. Design your section layout template using the section editor tools then copy the design template to each of the long section sub-sections. For a full description on using the section editor and copying master section layouts to individual sections, see Section Layouts.
Individual section layouts can then be tweaked, adjusting the location of labels and objects to present each section optimally.
Once you have completed the long section designs, sections can be exported in various forms for sharing with other stakeholders. For more information on exporting sections, see Exporting Sections.
