Importing Interval Tables
Interval tables that have not been imported during the borehole data import process can be added to the project at any time. To add an interval table, right-click on the Boreholes object in the project tree and select from the options available:
  • If the interval table is stored in a file on your computer or a network location, select Import From File > Interval Values. Leapfrog Works will ask you to specify the file location, and then will display the data in the file in the Import Interval window.
  • If the interval table is stored in an ODBC database, select Import From ODBC > Interval Values. You will be prompted to select the data source. See Selecting the ODBC Data Source.
Columns required are:
  • A borehole identifier
  • Start/from and end/to depths
  • A column of measurements
See Expected Borehole Data Tables and Columns for more information on the supported column types.
Select the required columns and assign the data type for each column. Click Finish to import the file, which will appear under the Boreholes object.
