Importing Drilling Data From the Central Data Room
Borehole data can only be imported from a project’s data room. Although borehole data can be published to Central, that is for the purpose of visualising the data in the Central Browser and the Central Portal. Published borehole data cannot be imported into other Leapfrog Works projects.
See the The Project Data Room topic in the Central 4.0 help for information on how to work with a Central project’s data room.
To import borehole data from Central, first make sure you are connected to a Central server. Next, click on the Borehole Data folder and select Import Boreholes via Central. In the window that appears, select the project you wish to import data from. The Import Boreholes from Central window will be displayed. Click the button for Collar to navigate the project’s data room to locate the collar file you wish to use.
Select the file and click Import. Work through the files as described in Importing Borehole Data.
