Cross Sections
This topic describes the process of creating a cross section, a slice through a model that can have a variety of objects evaluated onto it for presentation purposes.
A cross section is a section that is independent of other sections. Leapfrog Energy has other types of sections: Long Sections and Serial Sections. These other section types combine a series of sections into a single definition.
This topic is divided into:
Creating a Cross Section
To create a cross section in the scene, add a model to the scene. Next, right-click on the Sections, Plans and Contours folder and select New Cross Section. The New Cross Section window will appear, together with a section plane and controls in the scene that let you adjust the position of the section plane:
The New Cross Section window with the section plane shown in the scene, its front face tiled with the letter F and drag handles at its corners
If the slicer is already in the scene when you select New Cross Section, the position of the slicer will be used to define the initial orientation of the section. This is an effective way of creating a section from the slicer: add the model to the scene, draw a slice and then create a cross section.
The front (F) and back (B) of the section plane is indicated in the scene. To swap the front and back, click the Swap Front button.
Once you have created a section, check the section’s extents and orientation. The initial dimensions of the section on the page are determined by the size of the section plane, and its orientation on the page is determined by the front (F) and back (B) faces of the section plane. Usually you will want the front face of the section plane to be featured to get what you expect on the resulting section. Here, the front and back faces of the section have been swapped, which results in the section displayed on the page being flipped:
The section plane viewed from its back face and the resulting section page below, whose layers appear flipped left to right
Once the section has been created, adding the section into the scene is another useful way to check the orientation of the section is as expected.
Use the handles in the scene to position the section plane. The handles work in the same manner as the moving plane controls, as described in The Moving Plane.
Two buttons in the New Cross Section window let you create a cross section that is aligned north-to-south () or east-to-west ():
The two orientation buttons in the New Cross Section window outlined in red, one for a north-to-south section and one for east-to-west
The Lock section to slicer button () is enabled when it is highlighted in blue. Any changes to the cross section orientation will also change the slicer orientation when it is enabled. When disabled, the cross section orientation and position can be adjusted without changing the slicer. Click the Set section to slicer button () in the New Cross Section window to snap the cross section orientation back to the slicer.
Once the section plane is positioned as required, click OK to create the new cross section, which will appear in the Sections, Plans and Contours folder.
Section Layouts for Cross Sections
Create the section layout for the cross section, adding objects such as:
  • Geological models
  • Interpolants
  • Distance functions
  • Surfaces
  • Design lines
  • Alignment lines
  • GIS lines
  • Polylines
  • A plan view
Right-click on the section in the project tree and select New Layout. Use the section layout editor to design the section and communicate the information you need to convey.
For a complete description on how to evaluate models onto a section and use the section layout editor, see the Section Layout Editor topic. When creating multiple sections, consider using layout templates. See Working With Section Layouts and Layout Templates.
Displaying a Cross Section
You can add a cross-section to the scene by dragging it into the scene from the project tree or selecting View Object from the right-click menu. In the shape list, you can select the evaluation that will be used in the scene, including section layout, if available.
If you add a section layout to the scene, it will add the section to the scene and set the evaluation used in the shape list to the section layout you selected.
Two cross sections displayed in the scene, one with its layout, the other as the section only. Arrows from the shape list colourings point out the selections controlling the way the section displays.
Exporting a Cross Section
Cross sections can be exported in the following formats:
  • DXF Files (11/12 [AC1009]) (*.dxf)
The DXF format exports a single file with a collection of DXF lines based on intersections between the selected evaluation and the section planes.
For more information on exporting sections, see Exporting Sections.
For more information on exporting a section layout, which exports not just the section but also the page designed around it, see Exporting Section Layouts in the Section Layout Editor topic.
