Add Data to an Existing GM-SYS Model
The GMSANOM GX will extract magnetic and/or gravity data and station elevations from grids for inclusion into an existing (closed)
Add Data to an Existing GM-SYS Model dialog options
Existing model name |
The name of the GM-SYS Profile Modelling model. Script Parameter: GMSANOM.MODELNAME |
Magnetic grid |
Total magnetic field grid (nT). Script Parameter: GMSANOM.MAGAGRD |
Magnetic elevation grid |
Magnetic field observation elevation grid. (Must be in the "Vertical Distance units" specified below). Script Parameter: GMSANOM.MAGZGRD |
OR constant magnetic elevation |
Constant magnetic observation elevations; only used if no grid is specified for the magnetic elevations. Either Bouguer or free-air anomaly grid (mGal). Script Parameter: GMSANOM.MAGZCONST |
Gravity grid |
Gravity grid (milligals), either Bouguer anomaly or free-air anomaly. Script Parameter: GMSANOM.GRVGRD |
Gravity elevation grid |
Gravity observation elevation grid (+ up). (Must be in the "Vertical Distance units" specified below). Script Parameter: GMSANOM.GRVZGRD |
OR constant gravity elevation |
Constant gravity observation elevation; only used if no grid is specified for the gravity observation elevations. Defaults to Observation Elevation from current 3D model. Script Parameter: GMSANOM.GRVZCONST |
Minimum X (model coords.) |
The point at which the initial data value is extracted. (Must be in the "Horizontal Distance units" specified below). Script Parameter: GMSANOM.XMIN |
Sample interval |
Spacing between extracted points. (Must be in the "Horizontal Distance units" specified below). Script Parameter: GMSANOM.DX |
Number of points in profile |
The number of points to extract in the model profile. There cannot be more than 1,000 points in the Standard version of Script Parameter: GMSANOM.NX |
Vertical distance units |
Choose the vertical distance units from the list. All elevations must be expressed in this unit. Script Parameter: GMSANOM.VUNITSNAME, GMSANOM.VUNITSFAC |
Horizontal distance units |
Choose the horizontal distance units from the list. The "Minimum X" and "Sample Interval" (see above) must be expressed in this unit. Script Parameters: GMSANOM.HUNITSNAME, GMSANOM.HUNITSFAC |
If the grids used have projections associated with them, gmsanom uses them: otherwise it assumes the units specified by the Horizontal Distance unit. If the model does not have projection information in the .ECS file, gmsanom assumes that projection information found in the first grid is the same as the model and writes that projection information into the .ECS file.
