Plot GM-SYS Model Location
Run the GMSDATA GX to draw symbols on a map at the locations of gravity or magnetic data stations in a GM-SYS Profile Modelling model. Alternatively, you may draw a line showing the profile location from a "view" in the model.
Plot GM-SYS Model Location dialog options
Model name |
The name of the GM-SYS Profile Modelling model. Script Parameter: GMSDATA.MODELNAME |
Plot location of |
Choose "GRV" for gravity station locations, "MAG" for magnetic station locations, or "PROFILE" for a line indicating the extents of a model "view". Script Parameter: GMSDATA. DATATYPE |
GM-SYS Stations Plot dialog options
Symbol |
Select symbol number. Script Parameter: GMSDATA.SYMBOL |
Size (mm) |
Specify symbol size in mm. Script Parameter: GMSDATA.SIZE |
Weight |
Select symbol weight. Script Parameter: GMSDATA.SYMBOL_WT |
Line colour |
Select symbol colour. Script Parameter: GMSDATA.SYMBOL_COLOR |
Fill colour |
Select fill colour. Script Parameter: GMSDATA.FILL_COLOR |
Group by |
(0: Individual Symbols, 1: By Line/Group (default)). Grouping in the plot. If "Line/group" is selected, then symbol attributes can only be edited for entire lines or groups. If "Individual symbols" is selected, the symbols can be edited individually. The former selection is the default, and will be faster, especially for very large data sets Script Parameter: GMSDATA.GROUP |
GM-SYS Plot dialog options
Label size (mm) |
Specify character size in mm. Script Parameter: GMSDATA.SIZE |
Weight |
Select symbol weight. Script Parameter: GMSDATA.PROFILE_WT |
Line colour |
Select symbol colour. Script Parameter: GMSDATA.PROFILE_COLOR |
Extents from |
Select GM-SYS Profile Modelling model "view" to define line extents to plot. Choices are the view names saved in the model plus "User input". If "User Input" is selected, an additional dialog appears to enter X-min and X-max. |
GM-SYS Limits dialog options
X min (KM) |
Starting X-coordinate (in profile coordinate kilometers) for plot line. Script Parameter: GMSDATA.XLEFT |
X max (KM) |
Ending X-coordinate (in profile coordinate kilometers) for plot line. Script Parameter: GMSDATA.XRIGHT |
