Object Properties
You can view the properties of most objects imported into or created in Leapfrog Geo. To do this, right-click on the object in the project tree and select Properties.
The information available in the Properties window depends on the type of object. There are two tabs that appear for each type of object:
- The Processing tab shows the current status of the processing (queued to process, processing, finished).
- The Errors tab shows errors that have occurred while processing the object. See Processing Tasks.
Many objects also have a General tab that summarises information about the object. The amount of information in the General tab will vary according to the type of object. For example, for table objects, the General tab shows the table’s data structure.
A Histogram tab is included in the Properties window for some objects. See Statistics for more information.
