Displaying Structural Data
Planar structural data is displayed as disks and lineations are displayed as cones. There are several ways to change how this data is displayed.
Planar Structural Data
In the scene below, planar structural data is displayed using the Flat colour option, with positive (red) and negative (blue) sides shown:
You can change the colours used to display the different categories by clicking on Edit Colours in the shape list. In the window that appears, click on the colour chip for each category and change it as described in Display Colours.
The categories displayed can also be filtered by other columns in the data table, as described in Filtering Data Using Values and Categories.
Lineations
