Output Files (3D)
Use the Output Files dialog to convert the input 3D SEG-Y file to a Geosoft voxel, slice grids, and/or database. Specify which output type(s) you wish to generate and specify the names of the output files you wish to create.
Output Files dialog options
If a Geosoft voxel is generated, it will be displayed in the current 3D View, if one is open in the workspace. Otherwise, it will be displayed in a separate voxel viewer.
If slice grids are generated, they will be displayed each in a separate grid viewer. You may add them to a 3D View individually, or you may select a group of grids to display using the same parameters.
If a database is generated, it will be displayed in the workspace. The database file will contain a channel for each trace-header field that contains non-zero data, as well as an array channel for the trace data. The sampling (Z-coordinate information) for the trace data is stored in the Array Base Properties.
