3D Survey Mapping and Georeferencing
Use the 3D Survey Mapping and Georeferencing dialog to calculate the 3D geometry of the survey from 3 tie-points, consisting of Inline, Crossline and (X, Y) coordinate pairs.
The tie-points may be calculated from the trace headers, or specified explicitly by the user. The resulting volume orientation and spacing is calculated and displayed for verification.
3D Survey Mapping and Georeferencing dialog options
Source of tie points |
This is a contextual field; it displays the source for the tie points as specified in the 3D SEG-Y Coordinate Mapping wizard dialog. The text displayed is one of the two entries below:
Output survey file |
Browse or enter a new survey file name to store the mapping for use with another SEG-Y file in the same project. |
First tie point |
If the source of the tie points is “Calculated from trace headers", this row displays the Inline, Crossline, X, and Y coordinates of the first tie point calculated from the trace headers. If the source is “User supplied", the user must enter the four values for the first tie point. |
Second tie point |
If the source of the tie points is “Calculated from trace headers", this row displays the Inline, Crossline, X, and Y coordinates of the second tie point calculated from the trace headers. If the source is “User supplied", the user must enter the four values for the second tie point. |
Third tie point |
If the source of the tie points is “Calculated from trace headers", this row displays the Inline, Crossline, X, and Y coordinates of the third tie point calculated from the trace headers. If the source is “User supplied,” the user must enter the four values for the third tie point. |
Spacing along Inlines |
Read-only field showing the spacing along the Inlines calculated from the specified tie points. |
Inline orientation |
Read-only field showing the increasing inline direction calculated from the specified tie points. If the SEG-Y file is configured correctly, this value should differ by 90º from the crossline azimuth. |
Spacing between Inlines |
Read-only field showing the spacing between Inlines calculated from the specified tie points. |
Crossline orientation |
Read-only field showing the increasing crossline direction calculated from the specified tie points. If the SEG-Y file is configured correctly, this value should differ by 90º from the inline azimuth. |
[Text Header] |
Click this button to view the Text Header in a separate, read-only window. |
[Binary Header] |
Click this button to view the Binary Header in a separate, read-only window. |
