Pack and Send 3D View
The Pack and Send 3D View To option (SENDMAP GX) enables you to pack all the files (i.e., grids, voxels, geostrings, geosurfaces, projection information) that are displayed on a 3D View, into a single file and attach the file to an email in one step. This means that you do not have to worry about making sure all the files associated with a 3D View are included in the email. You can use the Pack and Sent 3D View To option to quickly send a 3D View; once it will be opened in Oasis montaj, the 3D View will appear exactly as it did before you sent it.
  • Access the Pack and Send To option from the 3D View main menu.
  • Access the Pack and Send 3D View To option from one of the following locations:
      • The Project Explorer > 3D Views section: select the 3D View and right click to access the context menu
      • The 3D Viewer Export menu
      • The 3D Viewer window context menu
  • A new email will be composed in your default email program with an attached packed 3D View (*.geosoft_3dv) file.
Packed 3D Views
Packed 3D Views are created using a compressed 3D View format that enables you to share your work with others. A packed 3D View is a single packed file that contains all the files associated with the layers added in the 3D View. These can be various 3D Objects (i.e. voxels, geostrings, geosurfaces, 3D symbols and drillholes) as well as 2D groups such as, oriented planes, relief surfaces and raster datasets.This means that you do not have to send multiple files in order for someone to view and edit your 3D View file, all of the individual files (i.e., grids, voxels, geostrings, geosurfaces and projection information) will be available in the current project.
