Batch Apply QC
Use the Batch Apply QC option (geogxnet.dll(Geosoft.GX.AirborneQC.BatchQC;Run)*), from the Airborne QC > QC menu, to apply airborne quality control in batch mode.
Batch Apply QC dialog options
Altitude deviation
Select the Altitude deviation check box to enable the Altitude deviation tab below.
Click here for technical help for the Altitude Deviation parameters.
Line separation
Select the Line separation check box to enable the Line separation tab below.
Click here for technical help for the Line Separation parameters.
Sample separation
Select the Sample separation check box to enable the Sample separation tab below.
Click here for technical help for the Sample Separation parameters.
Velocity deviation
Select the Velocity deviation check box to enable the Velocity deviation tab below.
Click here for technical help for the Velocity Deviation parameters.
Flight deviation
Select the Flight deviation check box to enable the Flight deviation tab below.
Click here for technical help for the Flight Deviation parameters.
Flight/tie differences
Select the Flight/tie differences check box to enable the Flight/tie differences tab below.
Click here for technical help for the Flight/tie Differences parameters.
Sensor noise
Select the Sensor noise check box to enable the Sensor noise tab below.
Click here for technical help for the Sensor Noise parameters.
Diurnal variations
Select the Diurnal variations check box to enable the Diurnal variations tab below.
Click here for technical help for the Diurnal Variations parameters.
Output map
Select the Output map check box to enable the Map name parameter below.
Map name
Specify the name of your output map.
This is a required field when the Output map field above, is selected.
You can select any number of quality control processes to apply to your airborne data. Each tab provides specific parameters for each of the quality control processes.
