One Step Correction to Free-air Anomaly
Use the Moving Platform Gravity > One Step Correction to Free-Air Anomaly menu option (AGTOTCOR GX), to calculate the total corrected free-air anomaly in one step.
One Step Correction to Free-Air Anomaly dialog options
Latitude channel |
The latitude channel name. The default name is "Latitude". Script Parameter AGTOTCOR.LAT |
Longitude channel |
The Longitude channel name. The default name is "Longitude". Script Parameter AGTOTCOR.LONG |
Height channel |
The elevation of the observation platform. For airborne surveys, this is the height above the sea level. The default will be set to "Height", if a channel by this name exists in the current database. Script Parameter AGTOTCOR.HEIGHT |
Hours to GMT (+ in West) (optional) |
This is the time difference between the time recorded in the survey database and GMT. This is a positive number in the Western hemisphere. If this field is left blank, no tide correction is applied. Script Parameter AGTOTCOR.GMT |
Input absolute gravity channel |
The absolute gravity channel name. The default name is "AbsGravity". Script Parameter AGTOTCOR.INCH |
Output Free-air anomaly channel |
The total corrected free-air anomaly channel name. The default name is "Free-air". Script Parameter AGTOTCOR.OUTCH |
The Total Correction includes the Vertical Acceleration, Eötvös, Tide (optional), Latitude, and Free-air corrections:
Total Correction = Vertical Acceleration Correction - Free Air Correction - Eötvös Correction + Latitude Correction - Tide Correction (optional)
See Vertical Acceleration Correction, Eötvös Correction, Earth-Tide Correction, Latitude Correction and Free-Air Correction for the formulas.
To obtain the Free-air anomaly, the Total Correction is subtracted from measured values of absolute Gravity from the L+R meter in mGal (Gabs).
