Save Current Map as ArcGIS MXD
Use the ArcGIS Tools > Save Current Map as MXD menu option (geogxnet.dll(Geosoft.GX.SaveMapAsMXD;Run)*), to save your Map (*.map) file as an ArcGIS MXD (*.mxd) file.
This functionality is only available on systems where a licensed copy of the ArcGIS ArcView or the ArcGIS ArcEngine exists.
Save Current Geosoft Map as ArcGIS MXD dialog options
New MXD name |
Specify the name of the MXD file. Script Parameter: ARCGIS_SAVEMAPASMXD.MXD |
Save for version |
Choose a compatible version of ArcGIS for which to save the MXD. |
Only the visible groups and views will be saved to the MXD.
Groups in the Base View as well as 3D views will be turned into custom graphics in the MXD layout and data groups will be turned into custom layers. The Geosoft Plugin for ArcGIS or the Geosoft Extensions for ArcGIS products are necessary to open and use these MXDs in the ArcGIS Desktop Suite.
