Apparent Density Calculation (DENS)
Use the Apparent Density Calculation option to apply an apparent density calculation filter.
Apparent Density Calculation dialog options
Thickness of model layer |
Thickness, in ground units, of the earth model t. |
Background density |
Background density in g/cm3, to be added to the density contrast map. The default is 0, which equates to the density map being relative to the average density. |
Apparent density mapping assumes a simple model layer of fixed thickness and varying density to explain an observed gravity field. The response is assumed to be caused by a collection of vertical, square-ended prisms of infinite depth extent, the horizontal dimensions of which are equal to the input grid cell size. This is an idealized approximation hence the descriptor Apparent. It is highly recommended to downward continue the data to close to the top surface of the source model, using the CNDN filter operator.
Where:
G |
Gravitational constant. |
t |
Thickness in ground units, of the earth model. |
Wavenumber domain variable definition
k |
u |
v |
r |
θ |
also
