Directional Pass/Reject (DPAS)
Use the Directional Pass/Reject option to apply a directional pass/reject filter.
Directional Pass/Reject Filter dialog options
Starting cut-off azimuth) |
The low cut-off angle in degrees azimuth, in space domain (geological strike). Note that this angle is 90 degree different from the k0 (see figure below) in frequency domain. ( = k0-90.0) |
Ending cut-off azimuth) |
The high cut-off angle in degrees azimuth, in space domain (geological strike). Note that this angle is 90 degree different from the k1 (see figure below) in frequency domain. ( = k1-90.0) |
Select "Pass" or "Reject" (Default is to pass the band). |
Directional pass/reject filter
Parameters:
k0 |
the low cut-off angle in degrees azimuth (from North). |
k1 |
the high cut-off angle in degrees azimuth (from North). |
0/1 if 1, pass the defined band; if 0, reject the defined band. The default is to pass the band. |
As with the bandpass filter, the directional-pass often suffers from Gibb's Phenomena ringing because the spectrum is cut so abruptly. We recommend using the directional cosine filter (DCOS) instead.
Wavenumber domain variable definition
k |
u |
v |
r |
θ |
Pass
Reject
also
