Subset Array
Use the Database Tools > Array Channels > Subset Array menu option (VA2VA GX) to create a subset array channel from a window of an existing array channel.
Subset Array dialog options
Input array channel
The name of an existing array channel.
Script Parameter: VA2VA.IN
Output subset array channel
The name of a new subset array channel to create. If the channel exists it will first be deleted.
Script Parameter: VA2VA.OUT
Subset start element ( > =0 )
The location of the first element to include in the subset (single element) data channel. The first element of the input data channel is 0.
Script Parameter: VA2VA.START
End element
The last element to be included in the subset data channel. This element will be reduced to the size of the input data channel if it is too large. The end element is included in the subset window, which will be (End – Start + 1) in size.
Script Parameter: VA2VA.END
