Array Section Colours
In the database window, use the right-click menu option Array Section Colours (VASCTCOL GX) to specify a colour zone file used to display an array channel in each database cell.
Set Section Colours for an Array Channel dialog options
Array channel
The array channel to display.
Script Parameter: VASCTCOL.CHAN
Colour table
Select the colour scheme for rendering the colour zone file. If you mouse over the colour scheme entry, a tooltip will display the name of the colour table in its folder. To modify the selection, click on the colour entry and then navigate through the scheme categories.
Script Parameter: VASCTCOL.FILE
The specified colour scheme file will be used to display an array channel in each database cell when the section display option is chosen (see VAPRFSCT.GX). Unless the specified scheme is a colour zone file, the colours are assigned using a Linear distribution.
