Apply Corrections
Use the Tie Line Levelling > Careful Levelling > Apply Correction menu option (LVCORR GX) to add a level correction channel to a raw data channel to produce a new levelled channel. The level correction channels can be created using LVSHIFT, LVTILT, LVSPLN or LVTSPLN.
Apply a Level Correction dialog options
Channel to correct
The name of the raw data channel to be corrected.
Script Parameter: LVCORR.IN
Correction channel
The name of the correction channel, normally calculated using one of the leveling GX functions.
Script Parameter: LVCORR.CORR
Output channel
The channel to store the result of adding the corrrection channel to the input channel. This channel can be the same as the input channel.
Script Parameter: LVCORR.OUT
Process line types
"Selected" to process selected lines (default).
"Tie" to process tie lines.
"Lines" to process normal lines.
Script Parameter: LVCORR.TYPE
